CC-Plugins CC-SysMonPro Software Plugin for HS4
$ 29.95 USD
$ 39.95 USD
$ 29.95 USD
CC-SysMonPro
CC-SysMonPRO turns HomeSeer into a monitoring and management console for the computers, storage and network gear on your LAN. A small agent reports CPU, memory, disks, SMART, temperatures, antivirus, pending updates, services and processes, and lets you reboot, run scripts, install Windows updates, and update or remove software without leaving HomeSeer. Everything it reads becomes a device, so any reading can trigger any event you already have.
- SMART health per drive, with the failing attribute named.
- Antivirus product, real-time state and how old the definitions are.
- Windows, Linux and macOS, installed and removed from the plugin's Agents page — no separate installer to walk around the building with.
- CPU, memory, disk free, uptime, signed-in user and full hardware inventory.
- Pending Windows updates, installed from HomeSeer with progress reported back; Linux package updates the same way.
- Installed-software inventory across machine-wide, per-user and Store packages, and what is out of date according to winget — with Update, Update all and Remove.
- Services and processes, with start, stop and restart.
- Printers and print queues.
- Reboot, shut down, run a command, run a saved script.
- An optional screen thumbnail, off by default and off per machine.
- Synology (DSM 6/7) and TrueNAS (CORE/SCALE): volumes, disks, temperature, packages and containers.
- UniFi controllers, devices, clients, ports and firmware.
- IP cameras: recording state, storage health and motion.
- UPS charge, runtime, battery type and mains state.
- A scheduled internet speed test with history and data-use accounting, plus your public address, its carrier and how long it has held.
- Network discovery: scan a subnet, name what is on it, and be told when something new appears.
- A health score for each device and for everything together, from thresholds you set globally or per machine.
- Alert rules on any reading, with a duration, a severity and a notification.
- Triggers for a reading crossing a line, updates waiting, software out of date, the public address changing, or a machine that stops answering.
- Actions to reboot, shut down, run a script, install updates or update all software.
- Every reading is published as a HomeSeer device, so the rest of HS4 can use it.
- A full asset report: make, model, serial, processor, memory, BIOS and age, operating system, what is installed and whether it is current.
- An installed-software rollup across every machine.
- History and charts for every reading, with CSV export.
- Agents auto-update with plugin updates and can also be uninstalled through Homeseer.
- HomeSeer HS4-Powered System
- HomeSeer HS4 4.2.0.0 or newer.
- The agent needs .NET Framework 4.6.2 on Windows, or Mono on Linux and macOS.
- Agents are reached on TCP 8791 by default, on your own network only.
