CyberLogix Innovations Astrolabe Software Plugin for HS4
$ 24.95 USD
$ 29.95 USD
$ 24.95 USD
Astrolabe
Astrolabe gives HomeSeer a detailed awareness of the sky, computing the Sun, Moon, planets, stars, constellations, twilight, eclipses, occultations, meteor showers, ISS passes and observing conditions. Automation-friendly values are exposed through HomeSeer devices, while core positions are computed locally from JPL DE440 with IAU 2006/2000A handling and IERS Earth-orientation support. More than 600 automated checks validate the engine. Try the same astronomy at astrolabe.cyberlogix.net.
- Sun, Moon and every planet as HomeSeer devices, with rise, set, transit, altitude, azimuth and much more
- Core astronomy computed locally from the JPL DE440 ephemeris, with no account or cloud service required
- Stars and all 88 IAU constellations included, with optional per-constellation HomeSeer devices created only when wanted
- Civil, nautical and astronomical twilight, day length, true-darkness window, Moon phase, illumination and named full moons
- Eclipses, occultations, meteor showers, planetary conjunctions, oppositions and other notable sky events
- A Tonight view plus observing guidance that highlights what is actually worth going outside for from your location
- Planetary retrograde state plus upcoming retrograde and direct stations
- Optional online enhancements for ISS passes, cloud-aware observing conditions and location elevation
- Full astrology data set including tropical and sidereal signs, aspects, void-of-course Moon, lunar mansions, nakshatras and planetary hours
- Built-in Sky, About and self-test pages, backed by more than 600 automated validation checks before each build
- Public web version at astrolabe.cyberlogix.net lets you explore the same astronomy engine without installing the plugin
- HomeSeer HS4-Powered System
- Your latitude and longitude - HomeSeer's own location is used unless you set an override
- About 40 MB of disk space, most of it the JPL DE440 ephemeris the plugin computes from
- Internet access ONLY if you switch on the optional extras (satellite elements, cloud forecast, elevation lookup)
