GoControl GD00Z Z-Wave Plus Garage Door Controller - OPEN BOX
Regular price $ 89.97 USD
Regular price $ 119.95 USD Sale price $ 89.97 USD
Out of stock
Z-Wave Smart Garage Door Controller
GoControl's GD00Z is a Z-Wave Plus garage door controller that's designed to remotely and automatically open and close garage doors. The unit is easy to install and works with all Z-Wave certified smart home software and hubs.
Features
  • Broad Compatibility: Compatible with most automatic sectional garage door openers, including models from LiftMaster, Chamberlain, and Genie, provided they use standard relay-based controls.
  • Remote Access via Z-Wave: Allows you to open or close your garage door remotely through a Z-Wave certified gateway or security panel.
  • Enhanced Security with S2 Encryption: Utilizes Z-Wave Plus S2 security for encrypted communication between the hub and devices, ensuring secure operation.
  • Over-the-Air Firmware Updates: Supports over-the-air firmware updates, providing the latest product enhancements without the need for manual intervention.
  • Safety Compliance: Meets UL 325-2010 safety requirements, providing peace of mind regarding safety standards.
  • Audible and Visual Warnings: Provides both audible and visual warnings prior to door movement, enhancing safety by alerting individuals nearby.
  • Wireless Tilt Sensor: Includes a wireless tilt sensor that reports the door's open or closed status, allowing for accurate monitoring.
  • Easy Installation: Features a straightforward installation process: mount the unit, connect two wires, and pair it with a Z-Wave certified gateway.
  • Z-Wave Plus Certification: Certified under the Z-Wave Plus program, ensuring improved range, extended battery life, and additional RF channels.
  • Integration with Other Z-Wave Devices: Acts as a wireless repeater to ensure that commands intended for another device in the network are received, enhancing overall network reliability.
  • Z-Wave Plus Certified
  • 120v/60hz White
  • Signal (Frequency): 908.42 MHz, 9.6Kbps or 40Kbps capable
  • Garage door position sensor frequency: 345 MHz
  • GD00Z Control Module
  • Garage Door Sensor
  • Mounting Hardware
Condition
Open Box stock includes customer returns that have been opened or new items with damaged packaging. Most items are in 'like new' condition but some may have slight cosmetic blemishes. All open box items come with the original manufacturer's warranty and are also covered by our 30-day return policy.
