HomeSeer HS-WS100+ Z-Wave Plus Wall Switch - USED
$ 19.97 USD
$ 49.95 USD
$ 19.97 USD
Out of stock
Advanced Z-Wave Smart Switch
Our smart switch includes on/off control of lighting and other loads up to 15 amps and you can launch automations by tapping the paddle multiple times.
- Supports wireless on-off control of lighting and appliance loads
- Supports multi-tap and press & hold event triggers up to 3 taps
- Supports instant status when controlled locally
- Compatible with HomeSeer (and many other) home controllers
- Easy 'screw terminal' installation
- Includes Z-Wave signal repeater feature
Operation
Once installed, HS-WS100+ works like any other paddle-style switch and will turn the attached load on or off. However, add it to any HomeSeer system and you'll be able to trigger automation events!
- Compatible with US Z-Wave networks (908 MHz)
- 120 VAC, 60Hz
- 900 watt incandescent
- 200 watt LED / CFL
- 1/2 HP motor
- 1800 watts (15 amp) resistive
- Supports Z-Wave Plus features
- cUL, FCC, Z-Wave Plus certified
- HS-WS100+ wall switch
- Screwless wall plate NOT included
Important
These features are supported by all HomeSeer systems, including HS3 software and HomeTroller controllers. If you're using another brand of controller, be sure to check with that manufacturer to see if the central scene features are supported.
Condition
| USED these are customer returns that have been opened and installed. These units are fully operational but may have cosmetic blemishes and may also be missing hardware. This used item comes with a 90 day warranty and are also covered by our 30-day return policy. |
