1 of 8
Regular price $ 19.97 USD
Regular price $ 39.95 USD Sale price $ 19.97 USD
Out of stock
Z-Wave Plus V2 USB Stick
SmartStick G8 is a Z-Wave Plus V2 USB stick for use with HomeSeer, Home Assistant, and other Z-Wave compatible smart home software. SmartStick G8 offers extended wireless range and better security compared to previous SmartStick models. SmartStick G8 may be used with Z-NETs for a centrally managed, multi-network installation.
Clearance Stock
👉 All items are tested and are reset to factory defaults
  • Amazon Returns items are in like new condition but do not include the outer box.
  • Z-Wave Plus V2 (800 Series) Interface for use with HomeSeer, Home Assistant and other brand software and hubs
  • Supports Z-Wave Plus V2 (and older) Products
  • Upgrade-able from Series 500 or 700 controllers running ZDK 6.61 or higher (requires HomeSeer Z-Wave Plus plugin or ZWave JS UI 9.9.0 or later).
  • Supports Z-Wave S2 Security + Secure Vault™ - Requires Compatible Software or Hub
  • Supports Z-Wave "Smart Start" Inclusion - Requires Compatible Software or Hub
  • May be Used with Z-NETs in Larger Homes or for Secondary Residences or Outbuildings
  • Supports multiple Z-Wave international regions when used with HomeSeer or Home Assistant software or hubs.
  • Optional wall mount available for optimized positioning. Learn more
Migration
Migrate to SmartStick G8 from any 500 series or 700 series controller running ZDK version 6.61 or later. Read the SmartStick G8 Migration Guide for details.
Migrations may ONLY be performed using HomeSeer's Z-Wave Plus plugin or Home Assistant's Z-Wave JS UI version 9.9.0 or later.
👉 DO NOT use PC Controller to perform a migration. That will render the stick unusable and void its warranty.
  • Z-Wave Plus V2 Certified
  • Protocol: Sigma Serial API
  • Built-in 800 Series Z-Wave Module
  • Includes ZDK 7.22.2 (or later) library as of 10/2024
  • Field-up-gradable Firmware | Get Latest Here
  • Supports international Z-Wave regions when used with HomeSeer or Home Assistant software or hubs.
  • Compatibility: Any Z-Wave certified smart home software or hub (including all HomeSeer systems) running under Linux or Windows 7 (or higher).
  • Works with HS4 based systems running the Z-Wave Plus plugin
  • Works with Home Assistant running ZWave JS
  • Not compatible with legacy v3 or v4 Z-Wave plugin
  • For upgrading from another controller: HomeSeer Z-Wave Plus plugin or Z-Wave JS US v9.9.0 (or later). Previous controller must be running ZDK 6.61 or later.
  • SmartStick G8 Unit
  • Quick Start Guide
  • 1-year manufacturer's warranty
Important
  • Windows 7 or higher & Linux are supported.
  • Windows XP is not supported.
  • Supports multiple Z-Wave frequencies when used with HomeSeer software or hubs.
