HomeSeer SmartStick ZB (Clearance)
$ 22.97 USD
$ 29.95 USD
$ 22.97 USD
Low stock
Zigbee 3.0 USB Stick
Unlock the full potential of your smart home setup with the HomeSeer SmartStick ZB, a high-performance Zigbee USB dongle engineered for reliability, range, and seamless integration. Whether you're running HomeSeer, Home Assistant, OpenHAB, or Zigbee2MQTT, this dongle delivers robust connectivity and cutting-edge performance using the latest Silicon Labs technology.
Clearance Stock 👉 All items are tested and are reset to factory defaults
All clearance items come with the original manufacturer's warranty and are also covered by our 30-day return policy. |
- ✅ Wide Compatibility: Fully compatible with HomeSeer, Home Assistant, OpenHAB, and Zigbee2MQTT. Easily integrate with popular smart home ecosystems.
- 📶 Extended Range Coverage: Features +20 dBm output power and a high-gain +5dBi detachable antenna, ensuring stronger, more stable connections across larger areas and through obstacles like walls and floors.
- ⚙️ Powered by Silicon Labs ERF32MG21 Chipset: Built on the latest-generation Zigbee SoC, offering enhanced signal processing, energy efficiency, and support for a greater number of connected devices.
- 🔧 Plug-and-Play via USB: Compatible with Windows, Linux, and Raspberry Pi systems. Ideal for DIYers and professionals alike.
- 🔐 Secure & Stable Communication: Built-in hardware-level security features ensure encrypted communication between Zigbee devices and your smart hub.
- Optional wall mount available for optimized positioning. Learn more
- Transmission Protocol: Zigbee, IEEE 802.15.4
- Serial Interface Protocol: EmberZNet(EZSP)
- Wireless Range (90 Meters / 300 Feet)
- Operating Temperature: -10 to +50 C
- Weight: 23g
- Works with HS4 based systems running the Zigbee Plus plugin
- Works with Home Assistant running Zigbee ZHA
- Works with Zigbee2MQTT
- SmartStick ZB Dongle
- Long Range Antenna
- 1-year manufacturer's warranty
