HomeSeer Z-NET PRO (Amazon Returns)
$ 119.97 USD
$ 139.95 USD
$ 119.97 USD
Low stock
Z-NET PRO – Next-Level Z-Wave & Zigbee Control, Anywhere on Your Network
Take your smart home to the next level with Z-NET PRO, a powerful, network-connected controller designed to seamlessly send and receive Z-Wave and Zigbee commands through HomeSeer or Home Assistant. Whether you're managing a sprawling estate or a smart barn across the property, Z-NET PRO delivers fast, reliable performance—right where you need it.
| Amazon Return stock includes customer returns that have been returned to us. These units have been tested by us to ensure the Z-Wave and Zigbee chips initialize properly with a working HomeSeer system. All Amazon return items come with the original manufacturer's warranty and are also covered by our 30-day return policy. |
🔧 Key Features
- 📡 Dual-Protocol Control: Z-Wave + Zigbee - Run Z-Wave Plus v2 (800 series) and Zigbee 3.0 networks from a single device. Perfect for mixed ecosystems with lighting, sensors, switches, locks, and environmental devices without juggling multiple dongles.
- 🏠 Network Placement Where It Matters Most - Unlike USB radios that must sit next to your server or hub, Z-NET PRO connects via Ethernet or Wi-Fi, letting you place it centrally in your home or closer to devices for dramatically improved Z-Wave and Zigbee performance.
- 📶 Stronger Meshes, Fewer Dropouts - Z-Wave 800 series provides longer range, faster communication, and improved reliability | Zigbee 3.0 offers responsive control and efficient mesh networking for sensors and lighting Better placement + modern radios = a faster, more stable smart home.
- 🔐 Modern Security & Easy Device Inclusion - Supports Z-Wave S2 Security, SmartStart, and Network-Wide Inclusion, along with standard Zigbee pairing, ensuring compatibility with today’s devices and secure onboarding.
- 🔄 Designed for Advanced Automation Platforms - Built for HomeSeer HS4 and Home Assistant, allowing you to centralize automation logic while keeping radios off your main system for improved stability.
- 🧠 Simple Web-Based Setup & Monitoring - A built-in web interface and status LEDs make setup, configuration, and troubleshooting straightforward—no fragile USB connections or trial-and-error placement.
🌍 Global Compatibility
No matter where you live, Z-NET PRO is ready to work for you. Zigbee 3.0 uses the globally standardized 2.4 GHz band, and the Z-Wave module supports multiple international frequencies. Whether you're in the US, Canada, Europe, Australia, Japan, China, or beyond, setup is simple via Z-Wave Plus or ZWaveJS UI settings in your preferred smart home platform.
⚙️ Tech Specs
- Z-Wave Plus v2 800 Series Long Range Technology
- Zigbee 3.0 EmberNet Technology
- Field-upgradable Firmware
📦 What’s in the Box?
- Z-NET PRO Controller
- AC Power Supply
- Ethernet Cable
- Quick Start Guide Card
- 1-Year Manufacturer’s Warranty
🧰 Requirements
- Compatible with HomeSeer HS4 systems using Z-Wave Plus & Zigbee Plus plugins
- Compatible with Home Assistant via ZWave JS UI & ZHA or Zigbee2MQTT
- Not compatible with legacy HomeSeer v3/v4 Z-Wave plugins
