1 of 6
HomeSeer Z-NET PRO (OPEN BOX)
Regular price $ 119.97 USD
Regular price $ 139.95 USD Sale price $ 119.97 USD
Low stock
Z-NET PRO – Next-Level Z-Wave & Zigbee Control, Anywhere on Your Network
Take your smart home to the next level with Z-NET PRO, a powerful, network-connected controller designed to seamlessly send and receive Z-Wave and Zigbee commands through HomeSeer or Home Assistant. Whether you're managing a sprawling estate or a smart barn across the property, Z-NET PRO delivers fast, reliable performance—right where you need it.
OPEN BOX stock includes customer returns that have been opened. These units are in good shape but may have slight cosmetic blemishes. All open box items come with the original manufacturer's warranty and are also covered by our 30-day return policy.
🔧 Key Features
  • 📡 Dual-Protocol Control: Z-Wave + Zigbee - Run Z-Wave Plus v2 (800 series) and Zigbee 3.0 networks from a single device. Perfect for mixed ecosystems with lighting, sensors, switches, locks, and environmental devices without juggling multiple dongles.
  • 🏠 Network Placement Where It Matters Most - Unlike USB radios that must sit next to your server or hub, Z-NET PRO connects via Ethernet or Wi-Fi, letting you place it centrally in your home or closer to devices for dramatically improved Z-Wave and Zigbee performance.
  • 📶 Stronger Meshes, Fewer Dropouts - Z-Wave 800 series provides longer range, faster communication, and improved reliability | Zigbee 3.0 offers responsive control and efficient mesh networking for sensors and lighting Better placement + modern radios = a faster, more stable smart home.
  • 🔐 Modern Security & Easy Device Inclusion - Supports Z-Wave S2 Security, SmartStart, and Network-Wide Inclusion, along with standard Zigbee pairing, ensuring compatibility with today’s devices and secure onboarding.
  • 🔄 Designed for Advanced Automation Platforms - Built for HomeSeer HS4 and Home Assistant, allowing you to centralize automation logic while keeping radios off your main system for improved stability.
  • 🧠 Simple Web-Based Setup & Monitoring - A built-in web interface and status LEDs make setup, configuration, and troubleshooting straightforward—no fragile USB connections or trial-and-error placement.
🌍 Global Compatibility
No matter where you live, Z-NET PRO is ready to work for you. Zigbee 3.0 uses the globally standardized 2.4 GHz band, and the Z-Wave module supports multiple international frequencies. Whether you're in the US, Canada, Europe, Australia, Japan, China, or beyond, setup is simple via Z-Wave Plus or ZWaveJS UI settings in your preferred smart home platform.
⚙️ Tech Specs
  • Z-Wave Plus v2 800 Series Long Range Technology
  • Zigbee 3.0 EmberNet Technology
  • Field-upgradable Firmware
📦 What’s in the Box?
  • Z-NET PRO Controller
  • AC Power Supply
  • Ethernet Cable
  • Quick Start Guide Card
  • 1-Year Manufacturer’s Warranty
🧰 Requirements
  • Compatible with HomeSeer HS4 systems using Z-Wave Plus & Zigbee Plus plugins
  • Compatible with Home Assistant via ZWave JS UI & ZHA or Zigbee2MQTT
  • Not compatible with legacy HomeSeer v3/v4 Z-Wave plugins
