1 of 6
HomeSeer Z-NET PRO Network-Connected Z-Wave & Zigbee Interface
Regular price $ 118.96 USD
Regular price $ 139.95 USD Sale price $ 118.96 USD
In stock
Z-NET PRO – Next-Level Z-Wave & Zigbee Control, Anywhere on Your Network
Take your smart home to the next level with Z-NET PRO, a powerful, network-connected controller designed to seamlessly send and receive Z-Wave and Zigbee commands through HomeSeer or Home Assistant. Whether you're managing a sprawling estate or a smart barn across the property, Z-NET PRO delivers fast, reliable performance—right where you need it.
🔧 Key Features
  • 📡 Dual-Protocol Control: Z-Wave + Zigbee - Run Z-Wave Plus v2 (800 series) and Zigbee 3.0 networks from a single device. Perfect for mixed ecosystems with lighting, sensors, switches, locks, and environmental devices without juggling multiple dongles.
  • 🏠 Network Placement Where It Matters Most - Unlike USB radios that must sit next to your server or hub, Z-NET PRO connects via Ethernet or Wi-Fi, letting you place it centrally in your home or closer to devices for dramatically improved Z-Wave and Zigbee performance.
  • 📶 Stronger Meshes, Fewer Dropouts - Z-Wave 800 series provides longer range, faster communication, and improved reliability | Zigbee 3.0 offers responsive control and efficient mesh networking for sensors and lighting Better placement + modern radios = a faster, more stable smart home.
  • 🔐 Modern Security & Easy Device Inclusion - Supports Z-Wave S2 Security, SmartStart, and Network-Wide Inclusion, along with standard Zigbee pairing, ensuring compatibility with today’s devices and secure onboarding.
  • 🔄 Designed for Advanced Automation Platforms - Built for HomeSeer HS4 and Home Assistant, allowing you to centralize automation logic while keeping radios off your main system for improved stability.
  • 🧠 Simple Web-Based Setup & Monitoring - A built-in web interface and status LEDs make setup, configuration, and troubleshooting straightforward—no fragile USB connections or trial-and-error placement.
🌍 Global Compatibility
No matter where you live, Z-NET PRO is ready to work for you. Zigbee 3.0 uses the globally standardized 2.4 GHz band, and the Z-Wave module supports multiple international frequencies. Whether you're in the US, Canada, Europe, Australia, Japan, China, or beyond, setup is simple via Z-Wave Plus or ZWaveJS UI settings in your preferred smart home platform.
⚙️ Tech Specs
  • Z-Wave Plus v2 800 Series Long Range Technology
  • Zigbee 3.0 EmberNet Technology
  • Field-upgradable Firmware
📦 What’s in the Box?
  • Z-NET PRO Controller
  • AC Power Supply
  • Ethernet Cable
  • Quick Start Guide Card
  • 1-Year Manufacturer’s Warranty
🧰 Requirements
  • Compatible with HomeSeer HS4 systems using Z-Wave Plus & Zigbee Plus plugins
  • Compatible with Home Assistant via ZWave JS UI & ZHA or Zigbee2MQTT
  • Not compatible with legacy HomeSeer v3/v4 Z-Wave plugins
Would the Z-NET PRO replace my Z-Wave and Zigbee USB sticks or work with them?
It can do both if your hub supports multiple Z-Wave and/or Zigbee adapters. The main benefit of the Z-NET PRO is that it connects over Ethernet or Wi-Fi instead of USB, so you can place it away from your hub for better signal reach.
Does the Z-NET PRO work with Home Assistant?
Yes, via ZWave JS for Z-Wave, and ZHA or Zigbee2MQTT for Zigbee.
Can I migrate my existing Z-Wave devices from an older Z-NET to Z-NET PRO?
Yes, but plan for some manual work. Customers upgrading from earlier Z-NET models report the migration is straightforward if you follow the migration documentation closely, though some devices, particularly door locks, may need to be excluded and re-included afterward.
Does the Z-NET PRO work outside the US?
Yes. Zigbee 3.0 runs on the global 2.4 GHz band, and the Z-Wave module supports multiple international frequencies including US, Canada, Europe, Australia, Japan, and China.
Note that the unit ships with a universally-powered 5-volt USB power adapter with a US plug. A plug adapter (not supplied) may be required for use in other parts of the world.
