izDaikin Software Plugin for HS3
$ 0.00 USD
$ 0.00 USD
$ 0.00 USD
IMPORTANT: This software plugin is no longer supported. It will remain available for download in the HS3 updater but will not receive any future updates. Check out with this item in your cart to receive a free license.
This software plugin is designed to allow HomeSeer systems to a Daikin HVAC Aircon unit via the Real-time RTD-RA RS485 interface.
- Control your Daikin Aircon unit
- Read/Set Set Point, Louvre, Fan Speed, Mode, and Operating State
- Read Return Air Temperature, Coil Inlet Temperature, Outside Air Temperature, Run Time and Fault Code
- Poll the unit (via timer and as required via device control)
- HomeSeer HS3 or HSPRO
- Daikin HVAC Aircon unit
- Real-time RTD-RA RS485 interface
