CFGuy Random Software Plugin for HS3
Allows adding random phrases to HS events, and scripts.
Setup Phrases in Categories allowing you to pick a category to use.
Example: Setup a Trash day Category. Add several phrases and set up an HS3 event to speak a reminder so you don't forget to take out the trash.
Add wav files to the HS3 Media folder and you can use a wav file in place of a phrase.
All phrases and categories are stored in a database making it easy to save a backup. Choose from Access, SQLite, or SQL Server.
- Add random speaking to events and scripts
