W.Vuyk JowiHue Software Plugin for HS3
Regular price $ 39.95 USD
This software plugin is designed to allow HS3 to control many Zigbee devices like lights, remotes or sensors. The plugin can be used in combination with Philips Hue bridges, RaspBee or ConBee gateway in any combination. With the Philips bridge, the plugin can control all lights and sensors that are known to work with the Philips bridge. With the RaspBee or ConBee gateways of any brand Zigbee device that is compliant with the ZigBee3 standards can be controlled with HomeSeer.
  • Control Zigbee connected lights, remotes and switches
  • use bridge groups to synchronise color changes
  • Create and trigger scenes
  • Combine scenes into animations
  • Stretch animations till sunrise/sunset/set time
  • Take snapshots of current settings per light for use in scenes
  • Event triggering based on the status of lights, groups, remotes or switches.
  • Event actions on lights, groups, scenes and animations
  • Script commands available for detailed control
  • Keep track of estimated remaining lifetime for every light
  • Independent of cloud services
  • HomeSeer HS3 or HS3PRO
  • Philips Hue bridge or/and, Raspbee or/and Conbee gateway
