GoControl GD00Z Z-Wave Plus Garage Door Controller
No reviews
$ 99.95 USD
$ 119.95 USD
$ 99.95 USD
Unit price
per
Out of stock
Z-Wave Smart Garage Door Controller
GoControl's GD00Z is a Z-Wave Plus garage door controller that's designed to remotely and automatically open and close garage doors. The unit is easy to install and works with all Z-Wave certified smart home software and hubs.
Features
- Broad Compatibility: Compatible with most automatic sectional garage door openers, including models from LiftMaster, Chamberlain, and Genie, provided they use standard relay-based controls.
- Remote Access via Z-Wave: Allows you to open or close your garage door remotely through a Z-Wave certified gateway or security panel.
- Enhanced Security with S2 Encryption: Utilizes Z-Wave Plus S2 security for encrypted communication between the hub and devices, ensuring secure operation.
- Over-the-Air Firmware Updates: Supports over-the-air firmware updates, providing the latest product enhancements without the need for manual intervention.
- Safety Compliance: Meets UL 325-2010 safety requirements, providing peace of mind regarding safety standards.
- Audible and Visual Warnings: Provides both audible and visual warnings prior to door movement, enhancing safety by alerting individuals nearby.
- Wireless Tilt Sensor: Includes a wireless tilt sensor that reports the door's open or closed status, allowing for accurate monitoring.
- Easy Installation: Features a straightforward installation process: mount the unit, connect two wires, and pair it with a Z-Wave certified gateway.
- Z-Wave Plus Certification: Certified under the Z-Wave Plus program, ensuring improved range, extended battery life, and additional RF channels.
- Integration with Other Z-Wave Devices: Acts as a wireless repeater to ensure that commands intended for another device in the network are received, enhancing overall network reliability.
- Z-Wave Plus Certified
- 120v/60hz White
- Signal (Frequency): 908.42 MHz, 9.6Kbps or 40Kbps capable
- Garage door position sensor frequency: 345 MHz
- GD00Z Control Module
- Garage Door Sensor
- Mounting Hardware
