GoControl Z-Wave Garage Door Controller (OPEN BOX)
Regular price $ 30.00 USD
Regular price $ 25.00 USD Sale price $ 30.00 USD
Out of stock
Turn your existing garage door opener into a smart home device with the GoControl GD00Z Z-Wave Garage Door Controller. The GD00Z lets you remotely open and close a sectional garage door and monitor its open/closed status through a compatible Z-Wave hub or controller.
The GD00Z connects to the garage door opener's pushbutton wall-console terminals and works with compatible Z-Wave controllers, making it a convenient way to integrate your garage door into scenes, schedules, automations, and remote-control applications.
NOTE: This product is not compatible with MyQ garage door controllers.
OPEN BOX stock includes customer returns that have been opened. These units are in good shape but may have slight cosmetic blemishes.
Key Features
  • Z-Wave garage door control – Remotely open and close your sectional garage door using a compatible Z-Wave hub or controller.
  • Open/closed status monitoring – Included wireless tilt sensor reports the actual position of the garage door.
  • Audible and visual warning – Built-in beeper and flashing indicator provide a warning before remotely commanded door movement.
  • Z-Wave Plus certified – Provides reliable two-way Z-Wave communication and can act as a repeater within a Z-Wave mesh network.
  • Works with existing garage door openers – Connects to the opener's wall-console terminals rather than replacing the existing opener. Not compatible with MyQ.
  • Smart home automation – Use your garage door status and control as part of scenes, schedules, notifications, and other smart home automations.
  • Wireless tilt sensor – Mounts directly to the garage door for accurate position reporting.
  • 120V AC powered controller – Includes the required power supply and mounting hardware.
  • GoControl GD00Z Garage Door Controller
  • Wireless garage door tilt sensor
  • 120V AC power supply
  • Mounting bracket and hardware
  • Installation hardware
Compatibility
The GD00Z is designed for sectional garage doors with compatible automatic garage door openers. A compatible Z-Wave hub or controller is required for remote operation and automation.
Important: Compatibility can vary by garage door opener model. The GD00Z is not intended for single-piece garage doors, and some newer proprietary garage door systems (like MyQ) are not or may not be compatible.
Specifications
  • Wireless Protocol: Z-Wave / Z-Wave Plus
  • Z-Wave Frequency: 908.42 MHz (US)
  • Power: 120 VAC, 50/60 Hz
  • Controller Dimensions: 6.94 × 1.38 × 5.0 in.
  • Tilt Sensor: Wireless, battery powered
  • Operating Range: Up to approximately 100–130 ft., depending on installation and Z-Wave network conditions
