1 of 3
Spud Sinope Plugin for HS3
Regular price $ 39.95 USD
This software plugin is designed to interface HomeSeer with your Sinopé thermostats.
  • Allows HomeSeer to read room temperature, room setpoint, setpoint mode, heat level, outdoor temperature, etc...
  • Allows HomeSeer to control your thermostat setpoint and mode.
  • Allows Homeseer to set the Home/Away status for all your thermostats
  • Supports all Sinope thermostats: line voltage, low voltage, floor heating
  • Direct integration with HSTouch and ImperiHome through the thermostat API
  • Base on a local API, it is internet-independent.
  • HS3 or HS3PRO Software or HomeTroller system
Support
