stefxx Neato Botvac Software Plugin for HS4
6 reviews
$ 39.95 USD
$ 39.95 USD
$ 39.95 USD
Neato Botvac
Control and monitor your Connected Neato Botvac Robot Vacuum from HomeSeer HS4! Supports connected models (Botvac Connected, Botvac D3 Connected, Botvac D4 Connected, Botvac D5 Connected, Botvac D6 Connected, Botvac D7 Connected) with the latest firmware installed. Upgrade available: Learn more.
- Start, Stop, Pause, Resume, Dock (Send to Base), Spot, FindMe, and Map controls.
- Status, Alert, and Error information.
- Dustbin and Battery information.
- Configurable options for several reminders.
- Vacuum options (Eco, Turbo, Normal, Care, Deep).
- Spot cleaning options including cleaning size.
- Supports multiple persistent Maps and Zones.
- Access to the last 20 cleaning sessions (maps and statistics).
- HomeSeer HS4-Powered System
- Neato Botvac Connected Robot Vacuum
J
John I. Easy setup, and just works. Very happy with it's function! :)
j
jan v. Great plugin, works exactly as it should
L
Lawrence B. Works great. Can monitor several Neato vacs and command them.
H
HSv Easy setup and configuration. The plugin makes it easy to configure HS events to start vacuuming the house.
This plugin was the reason I went with Neato in the first place, and it hasn't let me down.
G
Göran H. Great to schedule claening
