stefxx UniFi Connect Software Plugin for HS4
1 review
$ 49.95 USD
$ 49.95 USD
$ 49.95 USD
UniFiConnect
Monitor and control your Ubiquiti UniFi Connect devices. Note that you will also need to install the UniFi plugin for this to work.
- HomeSeer HS4-Powered System
G
Gregg Suter If you have Unifi connect displays, this plugin allows you to control them, so definitely a necessary plugin if you want to automate them outside of the unifi system. Customer service from this developer is top notch if you ever have any issues with the plugins working with your particular configuration, and sometimes he needs to write a new beta version that will fix the issue you're having.
