UltraJones UltraGCIR3 Software Plugin for HS3
Regular price $ 39.95 USD
UltraGCIR3 is a HomeSeer plugin (HSPI) that allows you to use HomeSeer to control infrared (IR) devices, respond to sensor inputs and contact closures over a network using the Global Caché network adapters.
IMPORTANT: This plugin is considered to be feature-complete by the developer and no future updates are planned. Community support is available via the message board but direct developer support is not guaranteed. Be sure to trial this plugin before purchasing.
  • Support for an unlimited number of Global Caché devices.
  • Support the GC-100 and iTach Global Caché IR/Relay devices.
  • Automatically detects all Global Caché devices on your home network.
  • Ability to disconnect and reconnect a Global Caché device.
UltraGCIR3 HSPI Overview:
- UltraGCIR3 uses the Global Caché discovery protocol to automatically detect the Global Caché devices installed within your home.
- A HomeSeer device is automatically created for each discovered Global Caché module.
- Using the Global Caché iLearn utility, you learn the IR commands for your remote controls and save the results to a file.
- Using the IR Import configuration web page, you then import the learned commands for the desired IR module.
- Learned IR commands can be added, modified or deleted using the IR Devices web page.
- Once the initial configuration is complete, you can control your IR devices and relays using HomeSeer device actions.
  • HomeSeer HS3
  • GC-100 Network Adapters: GC-100-06, GC-100-12, GC-100-18, GC-100-18R
  • Global Caché’s iTach Flex
  • iTach Network Adapters: WF2IR, IP2IR, IP2IR-P, WF2CC, IP2CC, IP2CC-P
Comments / Notes
Supported Global Caché Network Adapters:
- GC-100 Network Adapters: GC-100-06, GC-100-12, GC-100-18, GC-100-18R
- iTach Network Adapters: WF2IR, IP2IR, IP2IR-P, WF2CC, IP2CC, IP2CC-P
- Global Caché’s iTach Flex
