Home Protection Bundle #1
In stock
Protect your home from intruders and water leaks with our Z-Wave long range products. This bundle features our popular SmartStick G8 Z-Wave controller, our DS100 G8 door & window sensor, LS100 G8 water leak sensor and MS100 G8 motion sensor. Save 20% this week!
SmartStick G8 800 Series Z-Wave Controller
SmartStick G8 is the perfect controller for your HomeSeer or Home Assistant smart home hub. It features the latest 800 series LR technology for superior long range performance.
Features
- Z-Wave Plus V2 (800 Series) Interface for use with HomeSeer, Home Assistant and other brand software and hubs
- Supports Z-Wave Plus V2 (and older) Products
- Upgrade-able from Series 500 or 700 controllers running ZDK 6.61 or higher (requires HomeSeer Z-Wave Plus plugin or ZWave JS UI 9.9.0 or later).
- Supports Z-Wave S2 Security + Secure Vault™ - Requires Compatible Software or Hub
- Supports Z-Wave "Smart Start" Inclusion - Requires Compatible Software or Hub
- May be Used with Z-NETs in Larger Homes or for Secondary Residences or Outbuildings
- Supports multiple Z-Wave international regions when used with HomeSeer or Home Assistant software or hubs.
- SmartStick G8 is field-upgrade-able, allowing users to install the latest firmware updates with any Windows PC.
MS100 G8 Motion Sensor
MS100 G8 is a compact, easy to install Z-Wave Plus smart motion sensor that's designed to report to your smart home hub when motion is sensed or when motion has not been sensed for a period of time. Use to track occupancy or monitor for security.
Features
- Motion sensor
- Magnetic mount
- Easy to install, easy to adjust
- Supports Z-Wave LR (Long Range) technology (when used with Z-Wave LR compatible hubs)
- Works with HomeSeer, Home Assistant, Hubitat and SmartThings hubs.
- Works on battery power or line power (optional AC adapter not included)
- MS100 G8 Full Description
DS100 G8 Door / Window Sensor
Our Z-Wave door & window sensor alerts your smart home hub when doors or windows are opened & closed. DS100 G8 works with standard or long range Z-Wave, supports S2 security, is easy to set up, takes regular AAA batteries and comes with all the hardware you need to install quickly. Works with most popular smart hubs.
Features
- Door / window sensor
- Uses conventional AAA batteries for easy battery changes
- Supports Z-Wave Plus and Z-Wave LR (long range) technologies
- Supports S2 Security
- Small and Sleek design
- DS100 G8 Full Description
LS100 G8 Water Leak Sensor
LS100 G8 is a compact, easy to install Z-Wave Plus smart water leak sensor that's designed to send Z-Wave commands when water is sensed or has not been sensed for a period of time. Use with your smart home hub to issue notifications or to automatically control devices (like smart water valves).
Features
- Water sensor
- Designed for free-standing or wall mounted installation
- Includes optional magnetic wall mount (with probe cable)
- Works with most Z-Wave certified controllers*
- Supports S2 security
- LS100 G8 Full Description
- SmartStick G8 (1)
- DS100 G8 door / window sensor (1)
- MS100 G8 motion sensor (1)
- LS100 G8 water leak sensor (1)
- User Guides
