1 of 3
HomeSeer SmartStick+ G3 USB Z-Wave Stick (CLEARANCE)
Condition
Regular price $ 24.97 USD
Regular price $ 39.00 USD Sale price $ 24.97 USD
Low stock
Z-Wave Plus V2 USB Stick
SmartStick+ G3 is a Z-Wave Plus V2 USB stick for use with HomeSeer HS3 or HS4 (and other) home automation systems. SmartStick+ supports Network Wide Inclusion (NWI) for easy pairing of Z-Wave products. SmartStick+ G3 may be used with Z-NETs for a centrally managed, muti-network installation. Open Box condition
Clearance Stock
  • Z-Wave Plus V2 (700 Series Chip) Interface for use with HomeSeer and other brand software and hubs
  • Supports Z-Wave Plus V2 (and older) Products
  • Supports Network Wide Inclusion (NWI) for Easy Product "Pairing"
  • Supports Z-Wave S2 Security - Requires Compatible Software or Hub
  • Supports Z-Wave "Smart Start" Inclusion - Requires Compatible Software or Hub
  • May be Used with Z-NETs in Larger Homes or for Secondary Residences or Outbuildings
  • Provides Easy Upgrade Path from previous SmartSticks, Z-Trollers, Z-Sticks and Most Other Z-Wave Interfaces
  • Supports multiple Z-Wave frequencies when used with HomeSeer software or hubs.
  • Z-Wave Plus V2 Certified
  • Protocol: Sigma Serial API
  • Built-in 700 Series Z-Wave Module
  • Includes ZDK 7x Z-Wave Library
  • Field-upgradable Firmware
  • Compatibility: Any Z-Wave certified smart home software or hub (including all HomeSeer systems) running under Linux or Windows 7 (or higher).
  • HomeSeer HS3 or HS4 system running Z-Wave plugin v3.0.6.0 (or higher) OR any software that's compatible with Z-Wave Plus V2 controllers.
  • See Condition Notes Above
Important
  • Windows 7 or higher & Linux are supported.
  • Windows XP is not supported.
